Terminating SWA with Wylex REC Supply Isolators | Page 10 | on ElectriciansForums
Discuss Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
Kent
I need to terminate 16mm SWA 2 core cable in Wylex REC Supply Isolators. Going to be using armour for earth. Whats the best thing to do with the earth. I have 12 of these to install. The only idea I have is to terminate armour on steel trunking then run 2 cores into Wylex REC Supply Isolators. Lastly connect earth back to intake. I'm sure there is a better way, I dont want to use steel trunking unless I have to?
See link below for Wylex REC Supply Isolators
http://www.tlc-direct.co.uk/Technical/DataSheets/Wylex/WYREC2.pdf
[ElectriciansForums.net] Terminating SWA with Wylex REC Supply Isolators
Slight revision, Cut-Out is slightly bigger, I've also set meters directly on trunking to reduce overall height and lift lower switchfuses.
UKPower Networks and EDF have both approved design, but I would be greatful of any further suggestions.
  • [ElectriciansForums.net] Terminating SWA with Wylex REC Supply Isolators
It's a big job, electrician is doing the work. This is just a small part of the job. The SWA runs off in a straight line, so no problem with SWA.
Well spotted, the cupboard is 90mm short, but I can easily make it higher, it's width that I can't do anything about.
I'll be making adjustment to cupboard, putting mounting board in and mounting Wylex on the wall, then DNO fitting Cut-Out, EDF fitting new meters and sparky connecting back to CU's.
UK Power Networks have agreed Cut-Out 100mm from floor is okay.
Reply to Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
Yes like that - fitted last week 😂
