Terrible kitchen install | Page 2 | on ElectriciansForums
Discuss Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
stuarth
Oxfordshire
Went to do a report on a kitchen install this morning and it was bad from start to finish, badly fitted units, not installed to the plan, badly tiled floor etc
on the electrics the electrician apparently dose not carry a spirit level
[ElectriciansForums.net] Terrible kitchen install
but the thing that worries me is the 16 amp oven wired into a 40amp switch straight back to a 32amp mcb won't the oven flex be rated to 16amps there for a fire risk when its on a 32amp mcb under fault?
If the oven incorporates a fan and other gizmos then it is not a fixed resistive electrical load. You need to consider also the cords capacity to carry fault current.
But in the event of a short circuit fault there will be very little difference in disconnection time between a B16 and B32. Having said that I'd probably put that circuit on a 16 or 20a MCB- unless the cooker isolator had a socket on it.
there you go with the negative waves. adding a socket complication, :D:D
Reply to Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
