Terrible kitchen install | Page 3 | on ElectriciansForums
Discuss Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
stuarth
Oxfordshire
Went to do a report on a kitchen install this morning and it was bad from start to finish, badly fitted units, not installed to the plan, badly tiled floor etc
on the electrics the electrician apparently dose not carry a spirit level
[ElectriciansForums.net] Terrible kitchen install
but the thing that worries me is the 16 amp oven wired into a 40amp switch straight back to a 32amp mcb won't the oven flex be rated to 16amps there for a fire risk when its on a 32amp mcb under fault?
I had this issue, when we had our new cooker installed recently. Rated at 8.7kW, installing 'engineer' insisted it had to have a 45A 10mm supply, which it did ;). And he then did the final connection in 10mm 6242y.
I put it on my clamp meter the other week, to see what current it does draw (you can have two ovens & a grill on), which is when I found out my clamp meter was u/s. Still reckon it won't draw than no more than 14A
Can you please post some pictures of the Terrible install? apart from a couple of switches being un level I am struggling to see terrible, a little heath robinson yes, but terrible?
No other pictures I am afraid, but if I tell you that the integrated fridge was fitted in such a way that it could be pulled out on top of you with very little effort, the appliance housing is out of level, the side panel has also been pushed inwards by 5mm meaning the doors can not be level, cornice & plinth cut to short, original sink binned and a smaller sink installed because installed the sink unit to close to the wall, wall units installed with out the fillers so the doors are rubbing against the walls, I could carry on but I think you get the idea, if it was my kitchen I would have it re-installed correctly but the customer has had enough and just wants a solution to the main issues.
mike.notonly are the sockets/switches notlevel,but the 3.5mm fixing screws don't have their slots aligned.that is terrible.
Next time get the photos put up. We can only imagine how bad it was. Until then we will take your word for it
Well my advice to to not pay the whole bill, do a snag list and speak to the fitter.
Both the fitter and spark have disappeared which is why the company asked me to go and see what needed doing, I will try and remember to take more pictures next week.
As said, the connecting 'flex' should have a suitable ccc for the max load of the oven, or whatever the manufacturer recommends.
Edit; Its always a challenge to line up so many faceplates, in one place. I use Home - http://www.spacerconnect.com/index.php/en/, even then, if the back box is not parallel with the finished surface, they can still be out of line. I use a laser level, to try and ensure they are level.
I'm lost to the point of the space connect things (what can they do that 2 brass bushs & a coupler can't?)
Oh dear, just a bit cheaper. Saves the planet (storing up plastic, save it being in the sea). Quicker. And it annoys you :D
It doesn't annoy me:p The website with "How it work" on the homepage is annoying though. And a 15mm spacer is bigger that a dual box so would leave a space between the faceplates so they aren't exactly side by side.
How much are they for 1 item?
Wasn't aware they where made from recycled plastic.
Reply to Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
