Terrible kitchen install | Page 4 | on ElectriciansForums
Discuss Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
stuarth
Oxfordshire
Went to do a report on a kitchen install this morning and it was bad from start to finish, badly fitted units, not installed to the plan, badly tiled floor etc
on the electrics the electrician apparently dose not carry a spirit level
[ElectriciansForums.net] Terrible kitchen install
but the thing that worries me is the 16 amp oven wired into a 40amp switch straight back to a 32amp mcb won't the oven flex be rated to 16amps there for a fire risk when its on a 32amp mcb under fault?
It doesn't annoy me:p The website with "How it work" on the homepage is annoying though. And a 15mm spacer is bigger that a dual box so would leave a space between the faceplates so they aren't exactly side by side.
How much are they for 1 item?
Wasn't aware they where made from recycled plastic.
The 15mm spacer is for mounting single faceplates side by side (is actually a bit of tight fit). Don't like dual outlet, ones I can get have fixed lugs? I tend to use the 35mm ones, so there is a decorative finish between two adjacent faceplates.
Think they cost about 50p each, probably not a lot cheaper than 20mm coupler & two brass bushes, but just think of such precious resources your saving, and the plastic is in a wall, not in your crisp packet ;)
They are quicker to install.
Apart from the aforementioned accessories not being level, oven flex and the 2 pin plug in shaver adaptor....
....What about the double socket with integrated USB charger? That is truly an abomination.
And whatever's sitting on the microwave is blocking the vents.
Its not just the fact that they arnt level that would annoy me its just awful to look at with all those FCU’s. I assume they are for intergrated appliances? Couldnt they have been put into an adjacent cupboard or even in a switch bank above work top?
I have to agree, apparently the sparks took out a grid switch setup and plonked all those FCU above worktop when they could have gone below, why? because they get paid for each point so ÂŁ40 for the machine connection then another ÂŁ40 for the FCU.
If you stick around long enough here, your find some members here feel that's the only way to do it :)
nah, all old hat that FCUs and grid switches. i use wireless appliances . no plugging in. just place in position and programme to connect to wi-fi.
Usage of these two types of back boxes below would have resulted in an appearance more pleasant to the eye. Usage of a spirit level or line laser would have ensured a perfect finish. There really is no excuse for such lazy, sloppy workmanship. Whoever did this merits a hard kick in the gonads.
The customer gave me the "electricians" Business card with his Facebook page on it, was surprised when I saw who his previous employer was, a well know well respected company who would not be impressed with his workmanship.
Usage of these two types of back boxes below would have resulted in an appearance more pleasant to the eye. Usage of a spirit level or line laser would have ensured a perfect finish. There really is no excuse for such lazy, sloppy workmanship. Whoever did this merits a hard kick in the gonads.View attachment 41591 View attachment 41592
Unfortunately, those boxes only work with standard size white switches, etc. The brushed metal ones the OP has are wider than the standard.
As above, some 20mm bushes may be a solution, or just plain care and workpersonship.
I always leave a box width between boxes this way it overcomes the issue of the socket plate sizes, allows plastering etc between boxes and if slightly unlevel sometimes not so noticeable. They should have left as grid switch. Hopefully, there is a bit of giving on the K.O. box.
Reply to Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
