Test failed due to missing RCD | Page 6 | on ElectriciansForums
Discuss Test failed due to missing RCD in the UK Electrical Forum area at ElectriciansForums.net
Hornchurch
Hi All
Recently joined the forum to ask for some information.
I recently bought a flat to let. I was advised by the letting agent to get the electrics tested, although not a legal requirement. The test was carried out by their electrical contractor. He failed the test due to the fuse board not having an RCD fitted. The fuse board is the original board fitted in 2003 when the flats where built. There has been no mods or circuits added to the system and everything is working as it should. I paid £348.00 for the test and the RCD to be installed. I have since been told that the test should not have failed due to the lack of the RCD. Have I been stitched up.
Any comments gratefully recieved
Peter
Should not have failed due to lack of RCD protection.
Flat was converted in 2003, no requirement at that time for RCD protection, other than for sockets which could reasonably be expected to supply portable equipment outdoors.
Never mind anyone getting "called out" the point in question was the safety of the landlords Tenants. Would you be happy if one of your family was living in a rental with no RCD protection? I will assume a "no" to that one, you can always take another view of course.
I would be perfectly happy for any member of my family to live in a flat above ground level without RCD protection. Presumably all flats were electrical death traps until the fairly recent introduction of blanket RCD coverage? I don't think so.
But you wouldn't be even happier if it did ?
Reply to Test failed due to missing RCD in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
