Looks nice
It seems this debate has been played over and over on this forum before.
3rd Amendment Metal Consumer Units - best practice advice please - Electricians Forums; Electrical Advice
Afternoon all, I've been doing domestic electrics for about 4yrs now and although I've done a few circuit alterations on metal clad consumer units I'd say that 95% of my work has been with plastic ones. I'm totally comfortable with replacing a consumer unit and all that it...www.electriciansforums.net
Totally disagree with the fact of there being an IET ?I am a member of the IET and totally disagree with it.
The problem is that the IET are a self appointed organisation that have published a paper called it the "IET Regulations" and it is not a statutory instrument and therefore not regulatory, a BS is advisory only.
Really, I thought it was about 'as far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames' which, if you accept that argument, means you need to do something the moveable flap on the front of a CU.The debate is over whether to leave an oversized hole in the rear of a CU that goes into a wooden partition.
Most new consumer unit have the door needed to be held up and there is a big difference between flames coming out of the front being dampened by the metal door than them going up between a wooden partition, especially if the consumer unit is a double stack one and the fire is on the lower bus bar.Really, I thought it was about 'as far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames' which, if you accept that argument, means you need to do something the moveable flap on the front of a CU.
As most manufacturers seem to leave this 'unlocked' and un-sealed, it does really seem to make that argument flawed, does it not?
Nobody said you had to use special glands, but it does say :I recall linking that video of Elex @ Harrogate 2015, but seems IET insist on you being a member to view it now, scallywags.
However, this ESF piece, calls itself 'Consumer Unit Myths'. I'm not sure of its date;
https://www.-----------------------...es/technical-e-news/consumer-unit-mythbuster/
It suggests the use of special glands etc, is a myth, which is demonstrated with the Hager hot wire test.
The video shows a Hager cu, without any flames coming out the plastic glands, plastic trunking entries and for that matter the flappy cu door.Most new consumer unit have the door needed to be held up and there is a big difference between flames coming out of the front being dampened by the metal door than them going up between a wooden partition, especially if the consumer unit is a double stack one and the fire is on the lower bus bar.
Is it necessary to use cable glands made from metal or intumescent sealing material for cable entries?
Good working practices such as minimising the size of a cable entry.
In any case, the requirements of regulation group 416.2 for barriers or enclosures must be met and manufacturers’ instructions, if any, should be taken into consideration.
I would also take into consideration sec 527.
The logic behind this is that such items should be of equivalent non-combustible construction in order for the intended requirement to be effective in terms of minimising the spread of fire originating from such equipment.
Hands across the table and all that, but it doesThe bit “Is it necessary to use cable glands made from metal or intumescent sealing material for cable entries?”
Should have had a “no” on the end![]()
The second bit was copied from your link, I should have taken it out, it also had a no on the end.Hands across the table and all that, but it does![]()
You're not the only one.So I'm getting a bit lost
You‘ve lost me, but I think we’ve discussed this enough now.The second bit was copied from your link, I should have taken it out, it also had a no on the end.
"Is it necessary to use cable glands made from metal or intumescent sealing material for cable entries? No"
So I'm getting a bit lost, are you not agreeing with what you quoted ?
