O
Discuss The gas man has been! in the UK Electrical Forum area at ElectriciansForums.net
So what was the Ze if any if you measured on the "earth bolt" on the main incomer
I'm at a bit of a loss here, ...So you have been to this installation and found that there is no main earthing conductor from the available earthing bolt on the lead sheathed cable. So what have you done (if anything) to resolve this issue??
Not at all!!
I was just curious as to what the conclusion to this situation was, as you gave no indication as to what you had or had not done (or going to do) to resolve. All you posted was that you tested a socket, with a duff value, so i couldn't quite see the point you were trying to make!!!
All this will require is about 30 odd minutes to resolve, if the Ze is sound off the DNO cable. I don't really see what the 40 years has to do with it, once a safety defect such as we have here has been noted/recognised, i would have thought this would be a priority work order to resolve...
Usually if you give a customer the indication that you have a responsibility to put it right they take that as a "well you have to do it for free" type arrangement. Or they tell you to go away as it sounds like your ripping them off as all they understand is that it has worked for 40 years so it can stay as it is. Then you don't really have an option except advise and walk away
Err!! it was the customer that called him in, on the good advise (in this case) of the gas fitter. So the customer knew, that there was a safety issue that needed to be resolved by an electrician.
have to disagree somewhat, here. murdoch got a Zs reading of 6.0 ohms,apparently from the services bonding, which is a better value than most TT systems can ever achieve , and it's been like that for 40 odd years! at the end of the day, he's planned to go back and sort it out: can't see the incoming water supply being converted to plastic within a couple of days. LOL.I personally would have tried to fix something up there and then as if by some chance the customer got some sort of injury or fatal shock since you have been there you might well find yourself liable or hounded to the ends of the earth by a no win no fee parasite.
If she would not pay for the work you could issue a formal letter to cover yourself
Reply to The gas man has been! in the UK Electrical Forum area at ElectriciansForums.net
