sean123
hi, i have just done my am2, which is the new version. i was never given a lot of information before hand so i will list done the equipment you have to install, this might help some people who dont know what to expect or never had any decent information given, like my self.
s plan heating system with solar sustainable energy element. basically a solar panel which controls a cylinder and has a sensor which is supposed to be on roof. 2 port valves, sensors for solar panels and boiler allready have pre wired flexes. the joint box is like a push in connector and u use feral crimps to terminate. all the information is the just follow the drawing. really quite easy.
3 phase motor - just supply in from board to pre wired dol starter and take the suplly out to the motor from starter in sy flex. so dont worry about control circuit because its allready there.
cat 5 - just one cat 5 from one out let and the other end goes to another outlet.
smoke alarm - fp from board to unswitched fuse spur then out on to tray ( use fp clips not cable ties) and to a carbon monoxide detector. thats it for that.
lighting - 2 way and intermediate with 1 light only in pvc/pvc.
ring - few sockets with one socket spuring of to another socket.
main bond to incoming gas and water.
6mm swa to a isolator which then feeds a 3 phase commando socket.
and thats it really.
they chuck in different size breakers in the box so that u have to think on which breaker to use, allthough u get give a db chart.
i hope this might help people who are about to take the new am2, so that you know what to expect.![Smile :) :)](https://cdn.jsdelivr.net/gh/twitter/twemoji@14.0.2/assets/72x72/1f642.png)
