This has me mystified! | Page 3 | on ElectriciansForums
  • Thread starter Octopus
  • Start date
  • Replies 34
  • Views 5K
Discuss This has me mystified! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Its a wooden floor and the mat is simply laid beneath it.
A floating laminate, or a tongue & groove solid wood? The solid wood tends to be glued and is generally more expensive and occasionally nailed, (which I doubt the floor fitter would be dumb enough to do this considering UFH is installed, or would he?).
Anyhow if the UFH installer is happy to come and sort it, that's just the job.
What will be very interesting is if you can find out exactly what the cause of the fault was and let us all know!! Cheers!
Hi - I've not used that foil, it looks fragile for flooring installer use (sorry to be blunt). My 20p is one of "the 3" has been punctured and is in contact with the original concrete floor (?), but you'd think IR would be lower ... And the buzzing is the mat vibrating in the space between new flooring and original floor (not properly secured?).
Customer response to 'buzzing'? I know I'd just say fix it please.
The foil type underfloor heating is a terrible idea in my opinion, I’ve seen it once before and I didn’t like it at all.
It is basically constructed like a rear window de-mister on a car, there’s a L and N bussbar formed by a copper strip running along each side of it with heating elements between them. All this is sandwiched between two thin flimsy bits of plastic.
Reply to This has me mystified! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
