Time for a game... | on ElectriciansForums
Discuss Time for a game... in the UK Electrical Forum area at ElectriciansForums.net
North West
2 points available.
1 )What is special about this meter/tester?
2) What is its name?
[ElectriciansForums.net] Time for a game...
More will be revealed.
Clues? Its a quite a special little unit of which I believe there are none left in existance. This was the only one of its kind and I believe there will be no more like it.
A prize of 1 thanks and 1 like, so all to play for... :sailor:
My stab in the dark
#Its not shown here The Museum of Technology, the Great War and WWII" where most extra old meters are found,so
Its a prototype universal avometer :hurray:
Good post by the way,so I'm going to give you a like because I likes
ha ha thank you
Although it wont be in the musuem becuase unfortunately there are none in existance, that are known of anyway.
I'll keep this going for a bit yet before I give the answers...
Another clue?
Well it has sort of been answered but I thought I would leave it too see if any one else knew.
OK, a stab in the dark. How about an AVO meter for blind people? Though how they'd read it, or why they would want one, I don't know.
Thats a fine stab in the dark sir as thats exactly what it is. Its an AVO meter for blind people.
it's an avo, obviously, think it's a model 8 modified. was it a blue peter project?
And you sir are also correct as it is indeed an AVO model 8 variant but to give it its full name it is an AVO model 8 braille (IIRC).
Introduced in 1951, this meter was designed to be used by the visually-impaired, and consisted of a more-or-less standard AVO7 with a 'feeler mechanism' pointer over the scale, swung from the movement, and braille markings moulded above the arc of the scale window for V, I and R. The switch positions have similarly-marked braille mouldings and a milled slot each of the range selector switches.
The markings on the braille scale are said to allow users to interpret readings to within 1% of FSD.
So reading the meter is all well and good but how would they know where to put the probes?!?! ha
This website has quite a few pictures and a badly translated description http://translate.google.com/transla...le.co.uk&sl=nl&u=http://www.pa4tim.nl/?p=1833
And while searching for this website again I stumbled across this site The Braille Avometer - UK Vintage Radio Repair and Restoration Discussion Forum
With some good information and also someone claiming to own one.
Prizes will be given out in due course....
Thanks; nice thread. I've never seen one, but the raised AC and DC symbols were the main clue for me.
Reading the translated article in the link, it sounds as if you connect to the circuit, then possibly lock the needle?, then move the external lever to make contact with needle movement, at which point you can then read the lever position on the braille scale.
I suppose if you were taking measurements in a repetitive manufacturing situation, or testing the same item of equipment in various locations, you'd get to know where to stick the probes.
Reply to Time for a game... in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
