I feel for you and know how it can be sometimes when you get sniped at. But I really cannot see throwing away thirty years after one low blow! Just update and fight back. What else can you do, shelf filling? I don't think so! Your employer has a duty to support and train anyone working for him. Why has he not assisted you, I would be asking that. Have you been sacked? No? well once more unto the breach then! or ....shelf filling.
Oh no you're not, get back here and argue about the rights and wrongs of sticking 2.5mm cable in a 32a mcb, that will go round and round and round and round and round until we all agree to disagree.
I do hope that is not a euphemism,for a personal short-coming,and a skinny bird...;)
In what situation is it the best solution? (Or even a good solution for that matter.)
Well I'd argue that it is well suited in the environment I was in today. An old club with voids all over the place. They don't want conduit/trunking running on the surface everywhere, and it would have been impossible to install conduit/trunking in the void as a retrofit. Being able to rod T+E in the voids allows for progress to be made.
I have used it, if mechanical protected ie metal trunking etc, no problem. Easy to use in commercial refurbs .
So why wouldn't you use singles in a containment system like that mentioned?
Also the cpc size is often likely to be unsuitable for the fault levels encountered in non-domestic installations.
Why not use something like Hi-Tuff then with the same csa (and insulated) cpc as the live conductors. I presume you have allowed for non-combustible supports for the wiring system and tried to prevent acrid smoke in escape routes?
I have never read so much twaddle in all my life. Fault levels in commercial are often similar to domestic with the same type of circuit protection. What Standards do you refer to, give us some numbers.
Time to call it a day
Commercial Electrical Advice
Sparkhe,
Andy-1960,
TrueNAS JBOD Storage Server
