OK if you cannot test kA then you should not be testing ?
if the earthing conductor is connected to the concentric outer ( N ), then it's TNC-S. if it goes to a metallic sheath, it's TN-S.
Should not have taken cover off and risked killing your self .You Could of used an earth loop tested to test ZE and then test between Nuetral and Live and if you get the same reading then its a TNC-S
If you can do that with di log 9083p I would like to know how.
Sorry don't Know the tester
swifters when you do your earth loop impedance test the PFC ka will be shown in bottom right hand corner of screen , use function button to change that reading to PSC ka , thats how I think that model works anyway. If the same TNC-S.
Fairly sure it can't be done! I know the fluke can but not the di-log it would appear!
Try reading the manual!![]()
And what about wooden back wylex CU's As long as there in a good condition there nothing wrong with them.
Found this link mate page 18
http://www.dilog.co.uk/downloads/17th/9083P Instruction Manual.pdf
