TNS or TNCS supply?
swifters
Hi all, please see attached? TNS or TNCS supply? Looks like it could be a TNCS but no notice to say that it is? IMG-20130805-00186.jpg
I'm sorry but some of the criticsm is a little unjust. Yes, the di log is a very easy to use multi function tester but no where in the manual does it say to join the neutral and earth leads together to perform a seperate pfc to distinguish between tns and tncs. Additonally, the way the readings naturally fluctuate I would say it is not always easy to interpret these results.
I can distinctly remember having a high ze value of 0.9 ohms on one job. Uk power networks came out and there was some ambiguity as to whether it was tns or tncs. He removed the service head cover and showed me it was tns. He didn't isolate the supply before removing this cover. He then took his own ze readings and they were just under 0.8 ohms. When I said I was getting readings of 0.9 ohms earlier he just shruged his shoulders.
Sorry but I don't think the criticism is unjustified, You're supposed to know how to carry out the full series of tests. If that means that you have to learn how to take them then that's what you do. Suppose something had gone wrong with this install and you found yourself in front of a judge, do you think the excuse of "There's nothing in the manual that says you do this" will cut any ice?
The bit about seeing a DNO gadgie doing this is hardly justification for you doing what you did. The DNO guys are trained and know how to do it properly and safely. I once saw a guy wrestle an alligator but I wouldn't dream of trying it.
Hey swifters,
As you ignored my last post I would welcome your comments on this:
Dear
Misrepresentation by South-London-Electricians
Thank you for your enquiry, regarding the misrepresentation by South-London-Electricians.
I can confirm that South-London-Electricians are not registered as an Approved Contractor or a Domestic Installer with this organisation.
We will now be investigating the misuse of our details directly with the contractor internally. If we do not receive an adequate response from the contractor, this matter will be passed to the local Trading Standards and posted on the NICEIC ‘Wall of Shame’ on the below link. Please note; while our investigation is taking place , we will not be able to provide you with updates on this matter.
NICEC | Householder | Wall of Shame
The NICEIC takes the misrepresentation of its logos very seriously and would like to thank you for the information you have provided.
Yours sincerely
Trisha John | Customer Relations Executive | NICEIC (A trading division of Ascertiva Group)
