Today's board change | Page 3 | on ElectriciansForums
Discuss Today's board change in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
This morning's job, in and out in 4 and a half hours. Vast improvement. Feel free to rip it apart and tell me I'm a fool and I've made a bodge of it and don't know what I'm doing.
[ElectriciansForums.net] Today's board change[ElectriciansForums.net] Today's board change
I did actually heat shrink the end of that line conductor and disconnect the relevant earth and neutral and shrink them the same, it was for a shower circuit thats not connect in the loft, they also got labelled accordingly.
You may say why the cable ties, I saw one of you do it the other week on here, Trev i think or GMES maybe? Looked nice.
[ElectriciansForums.net] Today's board change[ElectriciansForums.net] Today's board change[ElectriciansForums.net] Today's board change
Ok I know MCB 8 is on when it doesn't need to be, I did switch it off.
I'm intrigued with the circuit details sticker, where did you get them from, or did you print them yourself? I have always used Hager ever since I can remember unless something else is specced. Always have been very nice boards in my opinion.
See post 6 for info on this. I've seen quite a few hager boards where the stickers have all curled up and fallen off, I'm going to create a grid template on my label printer so that've can just bung them all in and off it prints.
I use 12mm clear on black super strength adhesive labels not the standard strength.
Ah yes, I do have a Brother label printer to mark up MCB's. I did mean the circuit detail list on the flap down lid (unless your label printer can do those too, mine definitely cannot).
Half of it wasn't covered by an RCD, there was a heat wise economy 10 supply in the left feeding one of the immersion elements which has now been converted to the whole installation as E7.
the customer just wanted a new unit as it's about to be let out and he wanted it all to be nice and safe.
Thanks for the positive comments everyone, it's nice to know others think it's ok.
It's basically fine, but i can't see any reason for anyone to use cable ties in a tiny domestic CU... I don't allow there use in our larger final circuit DB's either, they can become the cause of absolute nightmare tracing cables in a relatively small area, where most if not all the ties would need to be removed to enable to trace/find a single conductor.....
Reply to Today's board change in the UK Electrical Forum area at ElectriciansForums.net
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
