tonights 2391 exam....(10th march 2011)
L
lynj
one thing to say and that is did c&g forget how to be staightforward? :rolleyes: felt like some of the questions were half thought......
anyone else take it?
as phil stated cityand guilds have always made the questions on 2391 confusing,this i believe is on purpose as if they believe you should be able to work out whats required with limited input.
r
Upvote 0
I think that I put down two sets of periodic inspection reports, schedule of inspections/tests for the existing aspects, and one of electrical installation cert, schedule of inspections / tests for the new circuit.
Upvote 0
Thanks for reply newby, I basically put that only I put just 1 set of periodic etc! Bummer cos I think it was a 13 pointer
Upvote 0
good luck to you all now begins the slow wait hope someone found a mystery copy in there bag when they got home lol
then you can check through yourself to give you some idea of how you did
anyway hope you all passed
Upvote 0
**** it ,just got ****** after it,all the hard work and revision and for me the questions tonight were,well it seeems like the whole exam is luck on the night,done that Brian Scadden exam earlier today in me local library and got 86 percent over the two sections done the last four(that I got from the forum) and done great,yet tonight I thought the questions were worded difficult,(how many sepereate DBs wre there on that installation any way I've got the last four exam papers if any one wants them [email protected] and if any one can send me some cheers stroll on June)
Upvote 0
thats how i felt mate when i come out as i had studied for about 4 months every day as much as i could lol and by the end of the exam i was glad it was over but fuming at the way they word things but in the end all turned out well as i passed the june 2010 exam so all worth it in the end
Upvote 0
Q.a) In the shower unit, what visual inspections can you do to the c/u (4 marks)
B) explain answear to "a" (4 marks)
Upvote 0
Q. What test would you do on the rcd? (8 marks) I think it said to include time, mA
Q. What other test would you carry out on the rcd (2 marks)
Upvote 0
The marina needed a PIR doing for the local authority and new installation of 3 lights on the gangway.
Q. What 4 documents would you provide?
Q. Who would you consult for limits and extents?
Q. Who would you give your documents to?
Can't remember the marks or the question numbers.
Upvote 0
what size rcd? if 30mA then
did it ask for tester used etc better if you get a copy as the C&G speak needs to be read fully to understand there geeky language lol
A. Residual current device testing
test at 1/2X 15mA at both half cycles no disconnection
then test at 1 x 30mA at both half cycles disconnection in 300ms
then test at 5x 150 mA at both half cycles disconnection in 40ms
functional test
press the test button on the the protective device (RCD) to check correct operation of the mechanical parts are working correctly
Upvote 0
Electrical Courses
