R
robsparx
I may be in a slightly sticky situation. Before i start, i dont reccomend doing what I've done, as i understand it you should ALWAYS notify building control BEFORE you start a job if youre not registered to self certify
I had a rewire thrust upon me a few weeks ago when i was unemployed, so obviously i bit the guys hand off, and got to work straight away. I did'nt really think straight away about how i was going to Part P it.
I have nearly finished it now, and have arranged an ELECSA assessment for early june. But i have since found out that the house is being sold, and the deal is done and they have set the completion date for 2 days after my Part P assessment. So i am understandably more nervous about passing the assessment, and i'm not sure that even if i pass that the client will get the relevant documents in time?
Would it be too late to call out building control and get the to sign it off? The re wire is nearly finished, but its a totally empty house, so i can lift up floorboards etc showing my cable runs, and you can see exactly where i have run cables in the walls.
This is my own fault, i should have got building control involved straight away, even if the client didnt like the sound of the price
