Torque Multiplier | on ElectriciansForums
Discuss Torque Multiplier in the Electrical Tools and Products area at ElectriciansForums.net
IR
Not strictly electrical but anyone used them
Supposedly open the tightest truck wheel nuts with ease
No particular use for them but i'll be testing soon😁
[ElectriciansForums.net] Torque Multiplier
Simple gearing I expect… slower movement, but with inversely proportional force….
I can see that shearing a stubborn bolt head right off
Oooh. I need to torque a set of propshaft bolts back on my range rover to 650NM and I'd been wondering how to do that.... seems now I know!
(Because a standard long handle torque wrench won't physically fit and do the angles).
I have one, it's a well handy bit of kit!
It will move it or shear it, usually move it but had a couple of 20mm bolts it's snapped.
I tend to go in with some release spray and heat first, then give it some torque!
I've also used them many years ago, they're okay if there's a place available to anchor the foot and it doesn't matter if it leaves a divet in whatever it's sitting on. Maybe useful if you're working on heavy construction steelwork or structural anchor bolts.
Nowadays the newer generations of air and even cordless impact wrenches have made them mostly redundant, even my 18v Bosch impact wrench can apply over 1300Nm of torque and it's by no means the biggest or best. Also the mechanism of impacting is more conducive to seized or stuck bolt removal than just pure smooth torque.
Everytime i go out to my mechanic he tells some something different
Use a breaker bar 😁
I've got a new impact wrench here 😁
Makes sense alright impacting rather than smooth torque for removal
Reply to Torque Multiplier in the Electrical Tools and Products area at ElectriciansForums.net
Well I've had my new torque screwdriver for a couple of weeks, I wanted to use it as much as possible to see why it's such an emotive issue...
11K
Go on then, DM me. But I'm promising nothing!! 🤣
5K
After getting my --- kicked by the plumbing twice I was not in the mood for taking prisoners. This time I removed and dismantled the pipework and...
    • Funny
G
Hi fellow Sparkies! I've never posted before on this site and now I've retired its a bit late to frequent the pages of this forum but I need to...
Gumers
G
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
