TT System High z's | Page 5 | on ElectriciansForums
Discuss TT System High z's in the UK Electrical Forum area at ElectriciansForums.net
B
bluecallum
Testing a property with a TT system all circuits are reading a high figure for earth loop impediance,any suggestions done a rcd test on circuits the other day and it was not tripping at 1x but today is but at 5x meter is reading 25v.
so why is it not tripping at 5x now,and as i said earlier the other day it was not tripping at 1x
I would say your meter is set at 25 volts for touch voltage limits and as your RA is high you meter is now stopping the test on 5 X due to the touch voltage exceeding 25 V. 25/0.15 = 166 Ohms etc etc
Reply to TT System High z's in the UK Electrical Forum area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
