TT system tripping | Page 2 | on ElectriciansForums
Discuss TT system tripping in the UK Electrical Forum area at ElectriciansForums.net
mannex
United Kingdom
I am working on a TT system and the electrics are tripping all the time, I have narrowed it down to the downstairs light circuit. Everytime when this light circuit is connected at the board and if I try to turn the oven (on the cooker circuit) or boil a kettle. ( ring main) it trips the electrics, but when the lightning circuit is disconnected everything works fine. I have done the insulation. Test and its ok am now running out of idea. Because it seems the lighting circuit is interfering with the cooker circuit and ring downstairs main. But how its happening........... I am hitting a brick wall.
Help please
I had to reposition a light switch on this light circuit and I have since double checked my wiring. The rcd is tripping not the mcb
264 what mate?
264 ohms is bad, 264 Megohms is good. You need to be more specific, around x isn't really good enough for us to help you properly.
What's the back story to all this? You've been asked a couple of times.
Let's go back to absolute first basics.
How long has this fault been showing itself? If everything has been working normally as it should then something has happened to make this fault appear, you need to find out if the customer has had any recent work done.
Were you testing the circuit properly? IE all conductors disconnected, lamps out, dimmers removed, switches in the on position, 2 ways operated etc.
Have you tested between circuits to eliminate cross connections?
What were the IR results L-N, L-E, N-E.
You've been asked a lot of questions on here that you haven't answered mate
Trev.. The stroy is I only repositioned the light switch but there is also a carpenter building a study wall so mybe there is a nail somewhere
Now we're starting to get somewhere. The back story I was on about was your role in all this mate, are you working under supervision as somewhere or other it says you're a trainee. Is this a job on the side?
Reply to TT system tripping in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
