Twin&earth and SWA installed loose on floor | Page 4 | on ElectriciansForums
Discuss Twin&earth and SWA installed loose on floor in the UK Electrical Forum area at ElectriciansForums.net
Warwickshire
Hi All,
The contractor working for Magnet Kitchens at my brother's house has run the sockets ring in 2.5 T&E, plus an SWA for the cooker supply, by laying these cables on the floor under the units.
I'm fairly sure this isn't acceptable - at least these cables should be clipped up against the wall (shouldn't they?).
We had actually expected the cables to be chased into the wall before the units were fitted, but they've done the electricals and plumbing after the fitout...
Any thoughts or comments? Many thanks.
Does no one have safety concerns for the spider in the pic?
Hum ..... let me quote from BYB p416
"If you are the person ordering the work, but not the owner of the installation, you should pass the certificate , or a full copy of it including the schedules, immediately to the owner"
17th Edition 632.1, AMD1, AMD2 & AMD3 Following the initial verification required by Chapter 61, an Electrical Installation Certificate, togetherwith schedules of inspection and schedules of test results, shall be given to the person ordering the work. These schedules shall be based on the models given in Appendix 6.
18th Edition 644.1 Except where Regulation 644.4.201 applies, upon completion of the verification of a new installation or an addition or alteration to an existing installation, including the replacement of a distribution board or consumer unit, an Electrical Installation Certificate based on the model given in Appendix 6 shall be issued to the person ordering the work.
So... my brother cannot see the spec of the SWA embossed on it anywhere, but has just measured the OD of it: actually only 12mm.
By my reading of the datasheets, that makes it 1.5sqmm x 2 or 3 core.
So the CCC of SWA is much higher than that for the equivalent T&E (or tri-rated cable that I'm familiar with), but 1.5 still tops out at 27 or 29A, and I'd like to bet that the MCB is 32A rated...
Also, we can now confirm that there is an SWA gland into the CU, but no gland into the isolator - which is fitted in an inaccessible void behind a kitchen cabinet, so is no use as an isolator i.e. just functions as a terminal box...
Measuring the diameter is a bit hit & miss, a competent sparks would be able to assess the conductor size. In your picture, the swa looks bigger then 12mm OD, comparing it to the tw&e cables?
The isolator in 'an inaccessible void behind a kitchen cabinet', could you explain more, how is your brother expected to isolate the cooker?
Reply to Twin&earth and SWA installed loose on floor in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
