Two versions of lighting wiring | Page 2 | on ElectriciansForums
Discuss Two versions of lighting wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I didn't have an issue with the long hours, hard work, quick pace or the in-house EAL training. Had other concerns.
I've recently seen a C.E. install in an expensive new build house, garage fed in 1.5 SWA from a SFCU in the house, that can be acceptable but the actual surface wiring in the garage is rough, awful clipping and I'd say it was very much rushed/thrown in without any pride in the job at all.
More than 2, don't forget the JB system , yes still nothing wrong with it, if it a accessible. ( got to say that load of rubbish)
Still plenty of RB4's out there too. It was good system really and maybe may make a comeback. A modern version. Loop in method is a pain in anything but a pendant and wifi controlled switches like to a take up a fair bit of back box depth.
Apparently a team of three guys, 1st fix 2 houses a day. If that's true, That's going some!! Quality would obvs take a hit.
Reply to Two versions of lighting wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Com is short for Common, sometime just C, or in the case of your old switch , L1 It is the side of the switch that is always connected… the link...
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
