Urgent: 60 amp main cut out fuse required | Page 4 | on ElectriciansForums
Discuss Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
well it did!
Like i said before seen it a few times, last one was a screw in a cable, someone fitting surround sound speakers. dead short..
why don't you PM me some more abuse ????
there some great/helpful information and people on this forum, but there some strange ones on here.
I too have had a 60A DNO fuse blown due to water getting through a wall running down the twin and earths an causing a short at the socket outlet. The 3036 30A fuse was still ok.
I also caused a 60A to blow when I hit a diagonally run cooker cable while chasing out ,again the 30A 3036 was intact. Maybe years of overloading weakens them enough that they blow slightly faster than a 3036 under fault conditions.
You simply can’t beat the “bang” test for fault finding. I always thought the method was repair fault, replace fuse. Just shows how far behind the times I am.
PS regarding the extension lead, pull the other one it’s got bells on it.
Reply to Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
Apart from how you extend all the cables
Thanks for your feed back re- G99 SGI paper work i be file again. SSEN G99 SGI-1 fasttrack
