Urgent rcd !!! | Page 3 | on ElectriciansForums
Discuss Urgent rcd !!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I had something very similar a while ago, changed this guys board, everything meggered out ok before the change N-E
changed the board to the cheaper duel RCD option, the second i juiced it up, trip trip trip trip, unplugged everything it held, the min anything was switched on in kitchen - trip
one min was the kettle , the next the cooker, then the toaster, then the kettle again, this went on fall afternoon, all test readings were normal and neutrals were not mixed up
I changed the RCD switches 4 times still same problem
in the end the guy ordered me to stop work as worried about the cost, and ordered me to refit his rewirable fuse board
I did this and the problem 'went away'
to this day have no idea what it was
i look forward to hearing what you find
Thanks all for all replies update retested again and now coming up with a lower reading on n-e on both downstairs rings but they pass I have checked all the appliances with a extension lead and they all work as soon as I put the kitchen ring on it stays on but then when anything is switched on it trips
I have managed to get everthing on from the first floor upwords on the same rcd however it will not allow the other rcd to operate but if I turn off the first rcd then the second one will operate but will not take any load I have narrowed it down to downstairs lights and three rings downstairs and two rings in the kitchen may have been conected Somehow ?
How big is this house?:D
Are you telling us there are five 32A MCBs for the downstairs sockets alone??
How many ways is the board??
Seriously, can we have a picture of the wiring of your CU.
i ad this not so long ago on a rewire it turned out to be that the n was hit with the screw off a socket front so the rcd see the inblance with n - e so test between each circuit on n-e and im shore youll fined some thing
Sorry guys did not explain well, there is a downstairs ring and two rings in the kitchen/dining room, I'm based in chessington surrey and job is Wimbledon it's an old Victorian house which has a loft conversion and side !
10 way board will try and load pic does not look to bad :)
Crackin DB there chris nice use of Rcbos Vigies and Old style multi 9s could do with a small amount of "Tidying up " bets it also needs chart lol
my thoughts exactly been there seen that shops are the worst added to stuff disconnected n PIR put in list yards long nuffin done about it
Is the board from screwfix as this is usely supplied by them. I would go towards the 2 way lighting as I have come across this problem already.
ive just had the same problem that i was called out, ir test between all circuit conductors and ill think you find a connection between them (nail/screw though 2 different circuits neutrals/earths), when you find the problem resistance test them to show where the problem is. hopes this helps
Reply to Urgent rcd !!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Which rcd is it? Is it one for everything, one for a few circuits?
