• Please use style selector to select BLUE AND WHITE. If you are not already on it. This notice will go once you're on the correct style.
Using armour as earth
Hi,
ive been to look at a job today, used to be a pub a couple of years ago, now a house.
They have just gutted the kitchen and are going to refit.
There is s sub main (Henley blocks from head), 2 core 25mm SWA, run is approx 55 - 60 meters from head to board.
anyway, it needs a new board etc and a load of new circuits.
i just feel uneasy about using the steel wire on the SWA as the earth, I would rather have a 3 core or another separate earth.
ive not taken any readings as yet, only looked at it.
The only OCPD is the main fuse at present, I'd like a switched fuse put in.
what would you do regarding the earth? Would you use the steel?
Originally Posted by shanky887614
true but a lot dont fit bw glands outside they just use cw
Then they aren't fitting parts suitable for purpose. akin to fitting indoor sockets out in a pond.
CW's are the correct gland for swa cables outdoors.
in fit CW glands as a matter of course. irrespective of the IP rating, i find the CWs are far superior in clamping the armour with the taper olive as opposed to a silly bit of knurled brass.
F.. sixth letter of the alphabet. 6 part gland. 1 bit dropped in the 6" of mud at bottom of trrench.:hanged:
