se7aq
Can you use terminal blocks within a CU if cable is not long enough to be wired in numbered order, or the main bonding is not long enought to reach main bonding terminal in CU..?
Could this cause problems for future electricians if the neutrals are not in numbered order..? This may need to happen to ALL cables within CU.
Thanks in advance for your feedback best sarcastic answer wins a Mars Bar but sensible answers also welcome.
