OP
silverbantam
The alarm works ok but the tamper lights are on 3 of the keypads
Discuss Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
And the main control panel....enter engineer code the reset
ok we need to do some tests to find the fault......leave all cables in, and with short piece of wire, bridge out terminals D & C and also short out tamper terminals.....replace cover, and that should get rid of tamper light, then repost you result, and we will go from there
Reply to Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
