Veritas R8 alarm Control Panel Sound Problem | Page 4 | on ElectriciansForums
Discuss Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
True, but had to go through it section at a time, otherwise would end up chasing tails, but full marks Paul, it was the tamper spring.
Well.... What was disturbed first and what result did it give via a fault light? LETS LOOK AT THAT FIRST. The rest is just alarm engineering and making things work lol.
I don't think it has that. This is what it looks like inside the control panel:
I have the same board and I also has a tamper fault which is due to the spring. The spring has completely come off, how can I secure it in place? I also purchased a jumper with pins to override the tamper in JP1 next to the tamper spring button but as soon as I let go after putting the pins in the alarm sounds, has to be inserted with some force for the tamper light to turn off but diesnt remain in place. Thank you
  • [ElectriciansForums.net] Veritas R8 alarm Control Panel Sound Problem
Reply to Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
Shhh, don't tell the Chinese they want a bit of the action.
