Discuss Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
i haveI'm not sure but I would have the DNO out to look at it.
i have
all he ask was "is anything wrong with it"
and than "we can change it for a fee if you want"
Good point, i am not sure and dno guy put seal on the door nowNope I have seen some old stuff but not that. Is the neutral bar isolated from the enclosure.
This is in 1st floor and supply 2 flats on the 2nd floor.Is that the main incoming supply or in a flat?
There is another one on the ground floor but bigger with 4 fuses supplying ground and first floor.
So re supply to 2 flats, lets "assume" they are rewireable 3036 fuses, probably max 30A - so they are too small for the job (probably).
I think that this "fuse" is down to the flat owner - the bigger one downstairs is probably down to the supplier - where is the meter?
Reply to Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
