OP
JulianC
My guess is that Julian showers a lot, heats his water from gas and eats a lot of takeaways! :rofl:
Frighteningly accurate. Apart from the showering a lot bit.
Discuss Voltage Optimisation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Lots..
The voltis just goes into the tails, meter>voltis>CU, therefore drops the voltage on all circuits, so not so sure you would need to "re-wire" the house.
Just take care if a PV system has been fitted though.
I hope this helps.
But you cant put PV through the Voltis so a henley block and CCU is required if one isnt already installed.
View attachment 12166 There you go I have added a pic, This install has two separate phases, (Don't ask) so as there was space, very easy install.
^ That's the biggest problem with Voltage Optimisation: worthless opinions from people who've never used them.
My Voltis has saved me around 7-8%. Only fitted it to see if they work. As far as I'm concerned, it does.
Like I said, I fitted one to try it out. I was sceptical. It cost me nothing. I have no vested interest. I fitted it purely to see if it works. I have made no other changes to my consumption patterns (it's increased if anything). As far as I'm concerned it works. Of course, I'm sure that won't stop any of the nay-sayers debunking them, whether they've used one or not. Nor do I care.
I get the impression that no proof will be proof enough for some people. I don't think anyone has ever claimed these things work on (thermostatically controlled) resistive loads, bacause they obviously don't. Nor do they increase consumption in such circumstances. Less power for more time is roughly equal to more power for less time (ignoring thermal losses on me kettle of course)
You are correct no proof that they work is proof enough that they don't until some side by side proper scientific studies prove they do and we can rewrite some of the laws of physics
Not quite sure why you are having such a pop at JulianC, all he has done is showed that he had fitted one, and not made any other changes and it has saved him 7-8% on his electricity bill, whether we believe they do or do not work, it has saved him money, Fact.
Have a look at this, maybe it will explain things a little?
Voltage optimisation - for effective energy savings : Overview
If you are convinced that voltage optimisation does not work then fine, mind you many people believe that Solar PV did not work, but there thousands of panels bolted to roofs....
Reply to Voltage Optimisation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
