A
andrew692003
Hi lads,
I like the look and idea of these Wago connectors, never used them before but starting to think I need to get into the 21st century.
Anyway heres a few questions.
I do mainly private housing and commercial work so I do quite a bit of lighting(recessed) etc. so
1 - There are so many different connectors, what are the most common used for lighting etc that you use?
2 - Do you find the small Wago enclosures the best for housing these when recessing lights etc. or is there a better product out there you prefer?
3 - Would I be best to buy one of those kits for £75 or just buy a selection and see what I use more regularly?
4 - Where's the cheapest place to buy these fellows.
5 - Anything I need to look out for when using these connectors. Pro's and con's etc?
I would imagine I would only ever be using these connectors when joining/terminating 1.0mm - 2.5mm not sure I would use them for larger cables or if there would be any need for that really.
Anyway any info/links would be much appreciated.
Cheers
Cheers
