Wago Connectors? | Page 3 | on ElectriciansForums
Discuss Wago Connectors? in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
How many of you guys use wago clips and are they any good?
Is these considered as a professional consumeble products, or are they just a DIY gimmik?
I was doing some remmedial work on a new build recently and these things where everywhere you looked.
I had to remove a few in order to do my bit of remmedial work, had a little fiddle around with some of them but ended up getting fustrated with them and throwing them away. Just that I was thinking about buying a set of them and having another go with new ones, but if they are no good for anyone then I might not bother - Your input please??
Many thanks
Jamie
The push in ones, you can remove a wire by twisting back & forth, and you can reuse the connector. The lever ones you just open the levers to remove wires, and reuse. Agree with Tel, at first I was a bit sceptical, now I can't manage without them.
I never knew you could twist em! Tried it after reading this, amazing! Now I'm cursing all the times I've cut off 2 or 4 pole push one and chucked em!
Cheers SJD.
[ElectriciansForums.net] Wago Connectors?
Cheers SJD.
I would keep the ones you have removed cables from for temporary connections. Removing the cable in this way is not what the connectors were designed for, and I would not have faith enough that the internals were not stressed or damaged by this action to use them in a permanent joint.
I know what you mean, but it is detailed in the manufacturers instructions as the correct method for removing them
Wow, that surprises me. When I figured out I could remove them with a twist and a pull I expected the internals to be knackered. they weren't, but I still thought it a bit rough to reuse it. It's acting against the direction of the trapping blade and I just expect it to damage or at least stress them.
I'll still just use new ones for permanent connections I think.
Reply to Wago Connectors? in the UK Electrical Forum area at ElectriciansForums.net
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
