wago lighting connectors | Page 4 | on ElectriciansForums
Discuss wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Always useful to read the instructions first.
Common bloke thing, like setting up the tv :)
I've used them in a big plastic plastic box for lighting ....A job I had meant I couldn't get access to the ground floor lights for a rewire so i did the jb method and took s/l neutrals to all my lights and switchlines to my switches via the floorboards and up the walls ...Made a doddle of connections . Also those cage clips which allows flex to be connected to solid for fiddly lights with crappy connectors ( you know the ones guys cb's with no room to get 2 solid 1.5mm2 in and those awful brass mini connectors ) I put them in a wago box Its just small enough/big enough to get through say a 76mm downlight hole ....Also I use them to break into a ring then return the 2.5 mmm not used anything bigger though ...
Anything that makes our life easier surely is a good thing No ?
Reply to wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
