wago lighting connectors | Page 3 | on ElectriciansForums
Discuss wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The wagobox enclosure i have purchased for lighting? is the "Wagobox Light" version embossed on the enclosure but there is no MF embossed on the the inside of the lid or elsewhere.
It is smaller than the normal box but has cable restraints.
http://www.screwfix.com/p/wagobox-light-junction-box/8423fhttp:
If you need MF then it's got be a Wagobox as per post #5, they're the ones that have been tested and certified and have the approval stamp.
I like using the Wagobox in loft space for lighting (when adding fancy luminaires, or Class 2 fittings). The box can be mounted on a vertical batten, so it's visible above the insulation, for when the next poor soul comes along :)
I've done this a few times, a bit of wood poking up through the insulation with a JB on it, think last time I used a Hager/Ashley though. Seem to remember it was the height of summer and the loft space was scorching hot, couldn't get out of there quick enough.
I found it very difficult to close the normal wago box lid shut with 4mm twin and earth yet the cable retainer did not seem that secure with 1.5mm
Reply to wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
