Discuss Wet Locations in the UK Electrical Forum area at ElectriciansForums.net
I kinda like them .Never have to worry about leaving lights on etc .Just wonder how they work if you dose off in a bath etc ? !Also known by the new trendy name "occupancy sensors".
Problem is with some toilet cubicles that mean they don't really see you, and you get plunged in to darkness!I kinda like them .Never have to worry about leaving lights on etc .Just wonder how they work if you dose off in a bath etc ? !
( Gap quite tight under my bathroom door .. No carpet ! )What stops someone from taking power from the hall receptacle?
Hopefully parents spot what their kids are up to !
THIS!Problem is with some toilet cubicles that mean they don't really see you, and you get plunged in to darkness!
Common sense, hopefully. Although that cant be relied upon.What stops someone from taking power from the hall receptacle?
I would say the opposite. If someone can plug stuff in they will, if they have to rake around the garage to find the extension lead used for the mower, etc, they probably won't use mains powered stuff near the water.I'd argue not having a socket in the bathroom increases the odds of an extension lead being used.
But looking at it from the perspective of the legislation and professional electricians, if you fit a socket near a bath and it leads to a fatality you have to answer the inquiry about "Was that a safe thing to do?" but if someone takes in an extension lead and kills themselves it is out of your responsibility (beyond the usual circuit testing and provision of RCD protection as required by the regs, etc)
How would they get killed with listed appliances and an RCD?
This is precisely what happens. A large percentage of our newer customers are foreigners who are perplexed that they cannot use their hairdryer in the bathroom. They have spent a lifetime doing it safely in their own countries. Their next step is to buy an extension lead and plug it into the hallsocket.I'd argue not having a socket in the bathroom increases the odds of an extension lead being used.
Same rules apply in that sockets should be adequately separated from any wet areas.All discussions in this thread up to now have been for conventional bathrooms.
What's the take on cases where a shower or bath is open to a bedroom, with no intervening door?
OK I should have checked before reply! Yes, 3m seems reasonable.But the regs. say 3m.
Reply to Wet Locations in the UK Electrical Forum area at ElectriciansForums.net
