What a Dork, yes I know I need a hobby | on ElectriciansForums
Discuss What a Dork, yes I know I need a hobby in the UK Electrical Forum area at ElectriciansForums.net
His 'jiggery pokery unit' is just a bodgy bunch of socket outlets screwed to some ply board and am I right that using a 3kW water heater as a ballast in case there is a fault on the hedge trimmer is a load of b*****ks!?
I think he must be working at a higher level than me, cause they never taught me that one at school. Must get one in the toolbox :rolleyes:
Sorry, being a bit sarky, it could have some use if wired in series to limit current flow if the scissors had a dead short. I'm used to using test meters for testing :)
I think DORK is the correct description, Don't be sorry Wilko it was posted as an amusement outlet, I have been trying to come up with another title for him but can't post what I want to.
Well I thought there were some clever people on this forum, but obviously this jiggery pokery board has you flummoxed! It's obvious to me that the jiggery pokery board tests the hedge trimmer circuit with a small amount of current so it doesn't give off a big bang if there's a problem, diverting the vast amount of current to the ballast until it knows the hedge trimmer circuit is sound. It then diverts the correct amount of current to the hedge trimmer. That gents is how a jiggery pokery board works. Simples. :D
His fun jiggery pokery unit is nothing more exciting than a series limiter, he's just added bits to make it look more interesting. Does the same thing as the lamp limiter i use when restoring radios.
Your right Pete: Dork he is, but he does sound like Frank Spencer :) Seems to have a love of the word Pop.
Incredible.... That by-pass plug on his jiggery pokery unit gets me, it must have live pins on the loose plug top when not being used if I'm not mistaken! Correct me if I'm wrong .. People!
Totally correct Andy, joking aside this bloke is dangerous. He turned a regular cut cable repair into a video in which he demonstrated what a complete Dork, as someone put it, he is. If the commando socket or BS EN 60309, as some call them, is disconnected the ends will be live.
Reply to What a Dork, yes I know I need a hobby in the UK Electrical Forum area at ElectriciansForums.net
i think dan was referring to the OP where they mentioned it was found when removing mirrored wardrobes.... maybe nothing to do with the mirror...
So, I’m more aiming for the domestic setting myself and I don’t plan on EICR straight away. I am almost certainly not aiming for the industrial...
