What code? bonding conductor | Page 3 | on ElectriciansForums
Discuss What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bit confused where does mounting it on battens come into it. The board in the picture clearly has the back knocked out, is mounted flat leaving conductors exposed to a combustible surface.
Like the Plastic CU
You can’t code it for being mounted on a wooden surface even with the back cut out IMO without evidence of a problem or even loose connections.
Bit like a plastic consumer unit which is combustible.
Check tightness of connections,tight and secure, no code.
I was replying generally to the idea of using rear knockouts. In the OP's picture it does look like the CU is mounted straight on a wooden surface, with the back knocked out. Not sure why I must say.
You can code it for being mounted on a wooden surface even with the back cut out IMO without evidence of a problem or even loose connections.
You mean can't code it?
Reply to What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Surely one of the most important parts of supplementary bonding is to bond the radiator and hot tap/pipe to the cold one. Both the hot tap and...
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
