what documents should be completed after initial veritication? | Page 6 | on ElectriciansForums
Discuss what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
I
Ian Smith
of the electrical installation. trying to find the answer on the internet but no luck so far. Thanks in advance.
whats bizarre? Tell me your major advantage for and EIC over minor? I'm not saying I disagree nor agree
Page 89/90 GN3 - thats my reason.
It's bizarre how Napit can contradict BS7671 and GN3 (although they're non-stat they are the standard)
I was just unaware that a MIWC would ever be used for a new circuit under any circumstances. It's obviouslly not wrong if you're a Napit member, and Kate has proved that.
Just out of touch from everything i've ever learnt.
When I do an EICR, I quote a 7671 reg no being contravened for all defects.
For an installation, in 99% of situations, it's conform to 7671.
In this instance, NAPIT are not conforming to bs 7671. But I am sure they base their certificates on it.
Strange. Have they discovered something we don't know about. If so, surely their clients should know all about it and the reasoning behind it.
this is a practice to get others quote in my reply ignore me
worked it out now I can sleep
i just wouldn`t be deviatin from BS7671 as if it all goes arse up....you cant wave Napit`s version of things in defence....
and i think this is a deviation.....
I DO HOPE that NAPIT read this thread and offer up their opinion, as most of us think THEY have got it wrong. We can't criticise their members for being mislead but NAPIT should really toe the line on such a rule.
Kate keep using the minor works if you are able too. Why make work for your self! The ECA form is the same.
It really isn't ... ive got the form in my hand now and it clearlly states on the ECA minor works.....THIS Minor Works Certificate is intended to be used for additions and alterations to an installation that do not extend to the provision of a new circuit.
Only Crapit are suggesting a new ring final circuit can be classed as a minor Job with a minor works one page certificate, they need to get a grip with this before they are laughed out of the industry, Ive never known anything like it, what next? a rewire on a minor works LMAO, Dist board Change on a Minor works lol
well...in theory you could just keep adding circuits and certing each one individually with these `minor works`.....
look, a new circuit isn`t a minor works is it....
Reply to what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
