what documents should be completed after initial veritication? | Page 5 | on ElectriciansForums
Discuss what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
I
Ian Smith
of the electrical installation. trying to find the answer on the internet but no luck so far. Thanks in advance.
BS 7671 are also only guidelines.
if as has been said previously competent persons scheme is happy for it too be used in this way then there are no problems.
BS7671 is only a guideline as you rightly say, but if you go to court and get prosecuted under the EAWR they will ask you why you didn't comply with BS7671, and if you reply "I worked to Napits rules" you are going to have a really bad day out in court, and you probably wont be going home for a while, and i can guarantee napit will say "Nowt to do with us your honour".
Cheers............Howard
It amazes me that we have an organisation, the IET, who are responsible for writing the regs,yet along come others,the scams, and change things to suit. Why can't we just have one song book and all sing from the same sheet?
Because nothing is simple in life.
I don't think it's the IET's fault its the scams faults for not reading and understanding 'the standard'. Instead they just make up their own rules because they think they own the trade, all the scams are as bad as one another - too much money involved for anything to ever change now though im afraid.
so it would seem that theres several different ideas floatin about for single new circuits..
as has been said already here i always had it that its an EIC for new circuits....obviously Napit see it different....
seems a bit hard n fast with no rules all this........
Just leave it as I'm wrong. I didn't mean to start a debate was just giving my opinion and really wish I hadn't.
BS7671 does state it, but I follow the instructions of NAPIT as I use their test sheets and they are my insurers, for public liability and professional indemnity. So I'm going to continue following their instructions. Clearly because I don't know what I'm doing anyway so it doesn't matter.
Kate....look at what howard has said at #61.....
that should be your guide here....
i agree that a `napit` minor works for a new circuit wouldn`t cut it....
stop using them love....
Kate pet - you're not wrong, you're doing as what Napit tell you which is fair enough.
I think it's just come as abit of a shock to people that information can get so muddled up from provider to provider.
Reply to what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
