what documents should be completed after initial veritication? | Page 4 | on ElectriciansForums
Discuss what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
I
Ian Smith
of the electrical installation. trying to find the answer on the internet but no luck so far. Thanks in advance.
I fill out test sheets according to NAPIT rules as I pay enough every year to be with them. It wasn't your comments on this thread making me throw my dummy out of the pram, it was abusive PMs. The moderators have now fixed this. Your comments just topped it off.
I came on here to talk about electrics and have a laugh, all I've had over 24 hrs of abuse. Sorry for flipping, just had all I could handle and I knew what my form said
I bet you'll get flooded with apologies Kate, they should remember that a woman is always right!
BS 7671 are also only guidelines.
if as has been said previously competent persons scheme is happy for it too be used in this way then there are no problems.
Its a British standard to which we are trained to work to. One of the reasons the competent person schemes are there are to see we comply with this standard. They shouldn't be making up there own rule's.
Is there a real problem with her using it for this work? nope, your just not complying with the British standard.
They are what we go by though, 99% of the time, and the major guidelines for qualification, regulation wise.
If the point in question came up in any sort of qualification exam, I can imagine where the marks would be awarded.
edit: know
Not saying it is right but should the proverbial hit the fan then if they use a MWC instead of a EIC then the brown stuff will fall firmly on then CPs door.
Aye i agree - she's only doing what she's told which is fair enough, but the scheme is wrong.
I wonder what would happen if you were to ring up napit and ask them to read the GN3 / BS7671 when it comes to test certs and see what they say.
To be honest (and i do read the info they say through the paper from time to time lol) elecsa could stipulate the same rule, but like i said when it comes to testing i read what GN3 says and not what elecsa are telling me to do.
Reply to what documents should be completed after initial veritication? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
