View the thread, titled "What is the difference between Domestic Installer and Approved Contractor" which is posted in Domestic Electrician Forum on Electricians Forums.
R
rwhite2012
Hi can someone tell me what the difference between a domestic installer and an approved contractor please?
I have a feeling an approved contractoris someone with nvq level 3 and 2391 test and inspect but im not sure and cant find this info out anywhere.
Thank you.
Domestic installer is deemed competent to work on Houses.
An approved contractor is deemed competent to work in all fields.
However that said there is absolutely no reason why a part-p or domestic installer sparks cannot work in commercial or industrial so long as he is competent.
To work in houses and to be able to notify your work you NEED a minimum of DI/part-p status.
To work in other fields you simply need to be competent no requirement for any scheme membership.
If that sounds confusing well that's because the whole lot is a big mess and the whole industry is confused by it.
I was just browsing for relevant posts for my project and I happened to stumble upon yours. Thanks for the useful information!
dave
Reply to the thread, titled "What is the difference between Domestic Installer and Approved Contractor" which is posted in Domestic Electrician Forum on Electricians Forums.
