What is the use of this? | on ElectriciansForums
Discuss What is the use of this? in the Electrical Tools and Products area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Local MKM builders had a DeWalt stall on Friday, and all I bought was some screwdriver bits. Can never have enough screwdriver bits!
Came in little tough cases, lots of torq and pz of the same sizes… masonry drills, but holders….
[ElectriciansForums.net] What is the use of this?
And this thing….
Some sort of bit holder… magnetic, but so is the other one…. This one has a sliding collar.
I can’t figure out it’s function.
Utterly confused.
@littlespark
One of those sleeved driver bits has been in my impact driver since I first bought one several years ago, they are great for up to no8 screws save so much pain😀
The only time it's changed for a long bit is when it's too fat to get in the fixing hole (like isolators where the fixings is in a deep recess)
I wouldn't go back to a normal bit holder!
Sy
Particularly useful for removing slot headed screws. The sleeve keeps the driver bit directly over the screw head, preventing it from sliding sideways out. Pity they don't seem to last very long, but then, only a couple of quid so worth having.
The sleeved bit does get full of dross and tend to seize up especially when doing a lot of overhead work as it all falls in the sleeve bit. Good blast with an air line usually sorts them out again for a while!
Sy
Reply to What is the use of this? in the Electrical Tools and Products area at ElectriciansForums.net
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
Indeed, a bit like the 3% volt drop limit for lighting circuits, even though LED lights are now the norm?
4K
Excellent, thanks very much for you’re reply!
sorry duane, Your dyslexic and im BLIND. I think you have done too much hard work not to bother with nvq/am2 as this can give you valuable rounded...
LankyWill
L
E
Answered Nelly. Cheers
eskimo39
E
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
