What would fit this DB | on ElectriciansForums
Discuss What would fit this DB in the UK Electrical Forum area at ElectriciansForums.net
london
Without changing the fuse board what would be the best way to get a 50a supply to a shower.
I was hoping If I could not get an RCBO just an MCB to supply an RCD unit.
Wishful thinking
Keep the existing fuseboard and add a separate 'mini' CU that has an RCD and an MCB in it (aka shower unit)
Or is that not what you are looking for?
[ElectriciansForums.net] What would fit this DB
Does that comply to amendment 3 mate?
Reply to What would fit this DB in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Thank you everyone for your comments Celia
