Where can I find 3mm thick steel capping | Page 4 | on ElectriciansForums
Discuss Where can I find 3mm thick steel capping in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Got a job where I need to run cables round outside of building under 50mm of lime render, need to put it in capping.
Where can I get 3mm steel capping? Any ideas as im struggling to find it.
Out of interest, if you used 3mm capping/plates, would you be connecting each of these lengths to earth? Daz
Reply to Where can I find 3mm thick steel capping in the UK Electrical Forum area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
Thanks for that link. I ended up buying this becasue I could buy it by the metre Pardon our interruption... -...
