Which consumer units are best | Page 4 | on ElectriciansForums
Discuss Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
Stockport
I have a very old Wylex fuse board which is need to bring up to current standard Amendment 3.
I believe my property is supplied using a TN-S
I'm looking for a new consumer unit that is 11 or 12 way but not sure which brands are best as I plan on going for all rcbo.
So far I've seen Schneider, Hager and Wylex units
Schneider do one called Resi9 that's top of range but can't find any places that sell them, I can only see the Easy 9 for sale
Hager do one called Design 30
Wylex seem well stocked but I hear their rcbos are over sensitive and trip a lot, also they have had a recall in the past so I'm not sure on their quality in today's climate
I'm just wanting some advice on what you guys like to install, money isn't an object so I'm not after any budget stuff
Can anyone post pictures of their installs, be it cabinets or new metal consumer units
The regulations make a distinction between the two along with all manufacturers. I think it's a bit more than just semantics.
The original 'consumer unit' was specific to domestic single phase installations and incorporated the cutout, metering, main switch and circuit protective devices into a single unit. This was in the 1950s.
What I can't find is a more up to date definition, other than the one in bs7671 which is not overly specific
View attachment 29126View attachment 29127
I know what you mean, but in reality it's semantics isn't it? When a fellow sparks says CU or DB you pretty much know what they mean...
IMO it seems like all CUs are DBs, but not all DBs are CUs...
Nope, switchgear has it's own definition and would normally encompass DBs, switch fuses, fused switches, busbar chambers etc etc.
Mainboard is not a defined term as far as I know, and not one that I think I have ever heard of before.
here you go, acti9 wall mounted switchgear
[ElectriciansForums.net] Which consumer units are best
(biggest board ive worked on is Schneider powerpact4)
Cough! Getting back the original thread; Wylex, Crabtree (same group), Schneider, Hager & MK Electric are all offering their new 'Amendment 3' domestic consumer units. I'm not sure I would include any others IMHO. My local wholesalers usually stock from all these manufactories, but only have Wylex currently available off the shelf, and only in a couple of sizes/flavours.
Seems that metal 'Amendment 3' boards are rarer than rocking horse pooh at the moment, so OP, you should speak to your electrician to see what he can obtain or wait a while till the shelves get stocked up and the guys here, can give their views, once they fitted a few. IMO the Hager one seems to of had some thought put into the design, the rest seem to have put the contents of their plastic CU's into a metal box.
im surprised no one has brought one out with a layer of fire mastic covering the inside XD that would contain the fire.
if there is a fire it will expand and cover the lot
what good is a cable grip for the tails if the problem is a loose or bad termination
Reply to Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
2 3
