Which unit/enclosure to house upfront RCD? | Page 2 | on ElectriciansForums
Discuss Which unit/enclosure to house upfront RCD? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening..
Just looking at a CU change on a TT. I'd like to put a 100mA S type RCD before the CU. Is a 2 way (4 spaces) amd 3 metal board my only option? Its a bit big!
you could enclose it in this:
[ElectriciansForums.net] Which unit/enclosure to house upfront RCD?totally fireproof.
, vandal proof, and Electrical Trainee resisatnt.
Have you investigated whether PME is available?
Pretty rare that it's not these days and I'd go for that every time over a TT.
No I haven't. What sort of price do they charge? Do they charge? Expect it varies between DNO's?
http://youtu.be/uOypkkgTEB0
look at 4 minutes into this video. It shows an insulated enclosure for an S type RCCB. so Wylex infer this is acceptable but as stated earlier, if you contact their technical department they will not confirm that it is actually compliant. Odd to show an installation design and then not actually make a firm statement on whether or not it actually complies.
Reply to Which unit/enclosure to house upfront RCD? in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
