Who's right? Hopefully me! | Page 4 | on ElectriciansForums
Discuss Who's right? Hopefully me! in the UK Electrical Forum area at ElectriciansForums.net
Drew34
Yesterday whilst doing my practical assessment (2365 level 2) I caused a bit of a stink.
I was working on a couple of 2 way switches with singles through pvc conduit.
As the training centre boss walked past he started over me having blue cable at the switches.
He kept saying 'why have you got neutrals?'
My response was ' I haven't. I'm going to sleeve them brown. Surly it's not neutral if it's not doing what a neutral should do it's just a cable until terminated.'
My tutor had no problem with this method.
Maybe I should have just smiled and pleased him.
Was I right?
It would matter if you had a 2 or 3 gang switch and needed to loop the L to the other switches.
Just connect one of the browns to the cpc and bell it out. It really doesn't present a problem. Worth remembering that bs7671 expresses a preference for conductors to be identifiable throughout their length and not just at the terminations.
If someone did it with a single I would expect them to rewire it properly.
An incorrectly pulled blue single sleeved and used as a line is very shoddy in my book and I would not permit it on new work at all. Forgive my unfamiliarity with T+E (I only work on projects that are in steel con, SWA and pyro) isn't twin brown usually made with one core insulated with solid brown, and the other brown-skinned white insulation, so you can tell the difference during installation? I've certainly seen red done that way.
Continental Europe does generally use an equal gauge insulated CPC but it's normally in a round cable rather than flat. Aus & NZ also have their CPC like that but the cable is flat like ours. USA T+E has bare CPC.
I have half a roll of Portuguese flat cable in my garage.
Not seen twin brown, but the twin red I’ve seen had nothing to distinguish the cores.
@Risteard doesn't the Republic of Ireland have it now that in T&E the CPC is both sleeved throughout and of the same size as the Live Conductors?
That's correct. The implementation date was the 5th September gone. It's roughly 30% dearer than BS T&E for IS T&E.
Reply to Who's right? Hopefully me! in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
