Why aren't ring circuits banned? | Page 5 | on ElectriciansForums
Discuss Why aren't ring circuits banned? in the UK Electrical Forum area at ElectriciansForums.net
C
chronyx
Doing a lot of EICRs in London at the moment and I'd say every other C.U. has a ring circuit with no continuity on one of the conductors.
Seeing as the IET see fit to tinker around the edges constantly with the regs, I struggle to understand why these potentially extremely dangerous circuits are still permitted. Yet bonding and earth conductors have almost doubled in size because, well, they said so.
It's not 1949 anymore. Ban the damn things.
Absolutely hate them! Can't see a place for them in a domestic situation.
Have spent 6 hours this week repairing one. ( boiler mounted over socket with broken
CPC + multiple non-compliant spurs)
I ve got another 3 to repair on other jobs - can't wait!
Why not put a FCU on the immersion so you can upgrade to 32A.
They are going to have a combi fitted so spur being removed. Also populated cu so can split this ring to feed 2 x bed sockets only and use the return to go on an 6 amp rcbo and put the outside light on there own curcuit . PS my name is Kevin and im a kitchen fitter .
Only went to fit the Kitchen n got this = pic
all the house was on on 1 general Failed tested rcd and when she put the electric heaters on as the rads where off (boiler change) the house shut down . The light ins tests are.85
Any one near Prestwich Manc want this one ? LOL
[ElectriciansForums.net] Why aren't ring circuits banned?
So you hate them because somebody poorly installed one?
I for one do not understand this thread, RFC are the recognised circuit,been going for decades.Is the dislike just pure laziness.?Is the today Electrician unable to fault such a circuit or even able to install it.? This is annoying me big time."!!
The today electriciam are able to fault find it. I was is fault finding when I done found the fault what made me post this.
Now you mention it I think you're right, not that I've seen much VIR
Slight side track, who knows the cause of 'weeping' older cables and green copper? I had it at the back of my mind it was a bad type of plasticiser that was used but I'm not certain.
Yes you are correct, with the early pvc cable, nothing wrong with it other than quite messy, just wipe it off. green gooey mess.
Reply to Why aren't ring circuits banned? in the UK Electrical Forum area at ElectriciansForums.net
