I've just started an apprenticeship with a decent sized firm (I got taken on full time - hooray!) and was thinking this week about how a lot of people, mostly online, turn their nose up at people who do domestic work.
I was wondering why, since at my work everybody seems to do the bare minimum but with most decent domestic sparks i know, they tend to go the extra mile.
Is there a difference in quality of workmanship simply because people want to do a better job for their own customers as opposed to commercial sparks who are simply getting the job done and aren't personally responsible for the final job?
Just seems to be a lot more 'just get it done' mentality on the commercial side.
Another thing i noticed is hardly anyone has the correct tools for the job and the tools they do have are mashed up.
So people will be using blunt cutters where the tip of one side has shattered off, or drivers with half the shaft insulation hanging off. Then there are other things which not bad but just 'doing it the hard way' like cutting PVC conduit with a hack saw having 3m of it flapping about instead of just buying a £10 pipe cutter, or using hammer and chisel/pad saw to cut out for back boxes where the wall is double skinned chipboard/plasterboard because nobody has a multi tool. Putting up conduit? Simply measure out from some maybe straight maybe wonky reference point and use your 6 inch torpedo level to get it right, instead of simply using a proper spirit level, making the job ten times easier.
When in the domestic setting it seems most people have the basic tools that make life easier.
Is it simply a case of 'not my job, don't care that much' on site compared with running private jobs directly in people's homes?
They do and it's not justified considering how technical the domestic work has got
I've seen the industrial electricians struggle with rcds a few times
It maybe that during the building boom, many people picked up the point that if they ;earnt a little bit of electrical knowledge they could quite simply wire a new build house, hence the phrase "!house basher" no training or not much anyhow.
After all one new house is much the same as the next one. Be honest not much to it is there? "
Whats the answer then??? if you have slung the wiring in one new build no difference than the last one or the next, after all you can become a DI in a few weeks if you choose the right course
I think it's fair to say that 30 or even 20 years ago wiring an average new build house was very straightforward, in my early 20s I could do a 1st fix, properly too in a good day. [Without any chasing].
But there's so much more in a current new build, probably 3-4 times as many sockets for a start, multiple lights where there would have been one in kitchens, utility rooms etc as well as things like heat pumps, electric underfloor heating and then data and alarm wiring etc etc. And the modern construction methods can be a pain where you have things like triple joists to get through plus crazy amounts of insulation everywhere and every other 'trade' seems to be on a mission to make life awkward for everyone else. So I still say that to do it right isn't as easy as many think.
I think you clearly have a lack of respect for the domestic side of electrics I’m not going into too much detail now because the AJ fight is almost on but you need a reality check my friend
Not at all Mate, I had 4/5 years on housing projects looking after and putting right sub standard work by substandard Sparks mostly Apprentices in thier las couple of years, or chancers who thought they were Electricians because they could sling Twin and cpc about with gay abandon, believe me Mate, new labour coming in as the jobs progressed I saw it all during those years, I have every respect for those that do domestic, it's the chancers that give domestic Guys a bad rep, sometimes the truth hurts.
I had the chance to get out of the domestic side and it proved to be the right move. Oh by the way I had my reality check eary on in my long career, went back to college, because during my time of day release there where those that spoilt the learning curve for the many pooh pooing the Science side of things," what do I need this stuff for when all I do is work on a building site day in day out, I worked with some good Domestic guys as well, not many but some as I say.
When you work with some lads that couldn't do a basic insulation test it does make you wonder what the trade was/is coming to, to answer your point that I have a lack of respect for Domestic Sparks, that's far from the truth.
Most of your work isn't going to be in new builds though.
Nobody says twin and cpc Pete come on, its good ole fashioned twin and earth. ??
Yeah......never used that term 'till about 20 years back.........it just appeared along with 'domestic contractors', 'Part P', a glut of 'membership schemes' and that other famous one relating to just over a month's worth of training.
.......can't quite remember that one, off hand. ?
