I've just started an apprenticeship with a decent sized firm (I got taken on full time - hooray!) and was thinking this week about how a lot of people, mostly online, turn their nose up at people who do domestic work.
I was wondering why, since at my work everybody seems to do the bare minimum but with most decent domestic sparks i know, they tend to go the extra mile.
Is there a difference in quality of workmanship simply because people want to do a better job for their own customers as opposed to commercial sparks who are simply getting the job done and aren't personally responsible for the final job?
Just seems to be a lot more 'just get it done' mentality on the commercial side.
Another thing i noticed is hardly anyone has the correct tools for the job and the tools they do have are mashed up.
So people will be using blunt cutters where the tip of one side has shattered off, or drivers with half the shaft insulation hanging off. Then there are other things which not bad but just 'doing it the hard way' like cutting PVC conduit with a hack saw having 3m of it flapping about instead of just buying a £10 pipe cutter, or using hammer and chisel/pad saw to cut out for back boxes where the wall is double skinned chipboard/plasterboard because nobody has a multi tool. Putting up conduit? Simply measure out from some maybe straight maybe wonky reference point and use your 6 inch torpedo level to get it right, instead of simply using a proper spirit level, making the job ten times easier.
When in the domestic setting it seems most people have the basic tools that make life easier.
Is it simply a case of 'not my job, don't care that much' on site compared with running private jobs directly in people's homes?
