Nearly everyone I know has more than one cutting board, where do they keep them, mostly on the worktops cluttering up the usable area, most of the people I know are average punter's. (wink face)
Yes. Unfortunately time teaches all sparks that the jigsaw is an essential tool when working in kitchens. I find replacing hobs to be the worst culprit in this regard.My own view on fitted kitchens is the concern that once an appliance dies you can't get a replacement that fits the "fitted" hole. In my own case i have very limited depth for the washing machine and recently found only 2-3 models out of 100+ on most sites would fit. Same issue with the fridge/freezer, NEF stopped making that size years ago so I had to get creative with the jigsaw to fit something else
Maybe not a concern for those who feel an "upgrade" is needed every 5 years, but for a tight-wad like myself I want to use the same layout for decades!
I like this, design by the way. Works a treat in utilities where homeowners are, nt fixated on appearance.The sliding tray space with door I have incorporated into our kitchen design in France, is also used to house the many cutting boards we have, it is so convenient I can't see us doing without it, cleans up the kitchen worktops and stops us have to search for
Nasty back handed slight.I like this, design by the way. Works a treat in utilities where homeowners are, nt fixated on appearance.
Mike. You have made me laugh. I can see in hindsight how it could be read that way. Believe me, no slight intended. I, m not clever enough for subtle humour (or sarcasm)Nasty back handed slight.
I've only got one chopping board... it's used so often it's almost become a permanent fixture to the worktop. In fact since the wife left me... it really has become a permanent fixture as it's kind of glued itself to the worktop. It's hard to see exactly what's holding it down with all the breadcrumbs and congealed bits around it though...
The sliding tray space with door I have incorporated into our kitchen design in France, is also used to house the many cutting boards we have, it is so convenient I can't see us doing without it, cleans up the kitchen worktops and stops us have to search for a cutting board.
From rings and radials to chopping boards. Gotta, love the versatility of this forum?We've got 2 chopping boards in use. And a glass worktop saver - does that count?
A final ring has many advantages. It is interesting on how it came about. The ultimate socket design is to have a radial to each socket outlet on its own fuse at the Consumer Unit - the optimum solution of course. One fuse at the Consumer Unit for each socket.I take it you're allowed to use radials for sockets?
So why does anyone bother with rings, seems like extra hassle to me.
This means you will need a very large consumer unit and lots of fuses (one for each socket) in the consumer unit, and an amazing amount of cable.
BINGO
A ring gives this by distributing the consumer unit around the house via a ring cable, having a fuse on each socket (the plug). The ring cable is a fused bus. This saves the vast expense of a plethora of radial cables back to the main panel and also a plethora of fuses at a very large consumer unit. This distribution saves on costs.
Simple and highly effective
For information. People read the threads.You're replying to someone who hasn't been on the forum since May 2020.
